NEW! ATX20 Lithium-Ion Battery 780 CCA
https://www.hdforums.com/forum/touri...-system-2.html
Well got the battery today, I installed it, it was charged at 13.7v at arrival, well it started my ride as if it was a scooter, no more turning over, it just fired up like a rocket, I will leave it a few days without any trickle charger as it is boiling hot outside so not riding for a day or 2, and if I get to the end of the 3 year warranty with it not letting me down, I will be really happy, it fits perfectly in the battery box just like Fatbob oem, if you get one of these keep your own battery terminal connectors, as they do not come with any, just flat round holes, not the best when you pay 500 usd for a battery, but as they say there is no small profit.
I'm wondering if what was done to the 110 program could be applied to other bikes. We all hear of hard starts. I certainly have ACR's on my Road Glide, wondering if they could benefit from earlier opening like the LRS did.
Anyway, keep us updated on how the Anti-gravity battery works out.
Smogbob (07-18-2017)
draw) on a 15 amp circuit and not blow it up. It only draws what it needs.
With regards to the slow starting, the stock battery only supplied so much power, so the starter slowed when it met load and couldn't draw more power from the stock battery to overcome the load. Right?
As regarding the warranty I sent them an email to see how the 3 years works, answer back is below.
Thanks for the good comments. No need to register for the warranty, you’re on our system now.
The warranty is graduated – 100% replacement in the first year, 50% contribution in the second year and 25% in the third year.
You mustn’t EVER let it discharge below 11.4v, that damages the cells and is not covered, so keep it on a maintainer when not being ridden. If you’re carrying out maintenance, connect a slave battery instead of the AG unit.
ONLY use a Lithium specific charger/maintainer, a lead acid/gel charger WILL damage the cells in the battery and can even cause a fire.
Apart from that – You’re all set.
If my 2012 SB is at home, its always connected to the trickle charger as advised by the dealer. I took the bike out for a weekend ride for a couple of days a few weeks back, without the charger, and it barely turned over on the last day. The battery was purchased from the dealer, last year, so it should be good.
Now I feel I have to take the power pak I have for jumpstarting, if I go away again. Don't trust that it will start on its own.
