Lowriser s take offs
Old Jul 29, 2017 | 07:26 PM
sgtrod91's Avatar
sgtrod91
Default Lowriser s take offs
My friend upgraded his lowrider s from110 to 117. Will his take off 110 fit a 2013 street Bob 103?
Old Jul 29, 2017 | 07:41 PM
Mchad's Avatar
Mchad
Probably not. The LRS ia purpose built 110 - the 110 upgrade kit for 103's have thinner walls at the base so it will slip into the 103 case bore. I doubt the LRS jugs will w/o boreing your case. Of course if that's an option for you, they sure they could work. Probably cheaper to take a different route then splitting your motor though.
Old Jul 29, 2017 | 07:52 PM
cvaria's Avatar
cvaria
make an offer:
http://www.ebay.com/itm/S-S-Cycle-4-...item2cb9345ac4
Old Jul 29, 2017 | 08:09 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
No, they will not bolt right up.
Old Jul 29, 2017 | 09:09 PM
Nickd2689's Avatar
Nickd2689
No. The cases would have to be bored. To my understanding the lrs gets the same 110 as the cvo models.
Old Jul 30, 2017 | 07:58 AM
Mchad's Avatar
Mchad
This is correct
Old Jul 30, 2017 | 08:19 AM
Nickd2689's Avatar
Nickd2689
I believe s&s has a 110 kit for about 1k. Might want to look into that. Or you can spend extra on the HD kit for 1800ish but that includes cams as well. Is this something you're serious about? Or just an opportunity that arose?
Old Jul 31, 2017 | 06:49 AM
sgtrod91's Avatar
sgtrod91
My friend told me if I could have them if they fit, probably look into a direct bolt on kit
ajmilberg
Jun 25, 2017 12:47 AM
619DYNA619
Sep 28, 2016 11:18 AM
Mike M
Mar 21, 2013 07:35 AM
thewholehog
Sep 26, 2012 10:24 AM
swomack
Apr 24, 2007 02:38 PM
