Low Rider S Bars and cables
I'm switching out my bars to Todd's 10" Strip Bars. I have the bars on the bike and the wires run through the bars (what a bitch). Looks like the wires are going to be just barely long enough. I will need to change the clutch cable and the brake line. Clutch cable is easy enough. Anyone change out the brake lines on one of these with the ABS yet? Looks like a simple distribution box under the trees to send fluid to the front and rear brakes, but I'm not sure if it's valved to send a certain amount to each. Any suggestions on the right set up? Pictures to come...
The cheapest way to go about this is to put +length lines for an FXDF from drag specialties.
When I installed my apes I used 1741-3830 which is a plus +8" (upper length of 31"). You would be advised to measure the length you need from the manifold under the tree to the brake reservoir to get the length you need. I just ordered based on part number recommendation and was almost too short.
http://asset.lemansnet.com/static/si...v2/#?page=1386
Zedrx (08-03-2017)
Some pictures of the progress
http://cubeupload.com/im/Zedrx/20170803070430.jpg
http://cubeupload.com/im/Zedrx/20170803070420.jpg
http://cubeupload.com/im/Zedrx/20170803070412.jpg
http://cubeupload.com/im/Zedrx/20170803070356.jpg
Code:
Front Brakes only Caliper Caliper ----- ----- | | | | | | | | ----- ----- ^ ^ | | | | | Manifold | | -------------- | | | | | -----| POST |----- | ______| | | | ----------------------- | | PRE |<--------| Reservoir/brake lever | | | | ----------------------- -------------- ^ | | | | | | | | | | v -------------- | | | ABS | | Controller | | | | | --------------
barricade (08-04-2017)
nightsterept
11-01-2019 05:34 PM
Kokes58
02-04-2015 03:41 PM
immusicman
11-14-2014 09:34 AM
