Best way to upgrade brakes
Have you seen this thread? https://www.hdforums.com/forum/dyna-...witchback.html
Thanks for the link. Yes, I had read that thread. The OP wound up going with better pads.
R6 radial caliper conversion
Hi Union53 (James),
I'm preparing to do upgrade to Sumitomo or Tokico calipers in dual set up on my 2010 FXDF. Bagger brothers brackets ordered.
Now I have been checking out calipers. On used parts sites lots of R6 units available, but as shown on image added to this post, these seem ot have bushings sticking out ? How did you deal with this ? specific shims ? grind them off ? can these bushings be removed. From your image I see that some shims are used, but what about these bushings ?
2nd topic : what banjo bolts are to be used ? size on FXDF master and size on R6 calipers ?
3rd : Could do with some tips on brake line dimensions and set up; checked out a site for ordering custom brakelines... looks rather complex due to all variations possible in links etc... I'll figure it out, but still some advice is well appreciated.
4rd : what about the brake light switch, does this needs addressing when using the original master set up ?
(conversion with the gold star sumitomo's looks great, I'm thinking of going for the silver colored version to have less colors on my vivid black Fatbob.
Hi Union53 (James),
1) The bushings come out. They are lightly pressed in. I've seen cases where they just fall out on there own. You may need a set of pliers to pull them out. My final solution was to make spacers that the bushings inset to. Since the post I made in this thread I've moved to dual disc and used a larger diameter rotor.
2) Harley in their infinite wisdom used two different sized banjo bolts. Originally on the caliper side I just used the banjos that came with the calipers. They work just fine. On the master side I used the banjo supplied by Brembo. These two are not interchangeable. Brembo uses a finer thread pitch.
3) In the photo above I made my own brake line. I used a Goodridge line and then just figured out what bend at the end worked best for that setup. When I moved to the dual disc setup I had a custom line made by Spiegler. You can spec them out many different ways. I chose to use the type 950 fitting. When figuring out lengths I found welding wire so be superior since it bends easy but is not floppy like string.
4) Using the stock master you should not have to mess with the light switch. I had to because this is an instance Harley has a unique setup compared to everyone else. I don't remember the exact details but it comes down to a normally open vs normally closed switch. The switch supplied by Brembo is one way which works for most bikes and the switch Harley used is the opposite way which in my experience is unique to them and their canbus setup. If they did it like everyone else then the switch supplied by Brembo would have worked fine.
jamesroadking
11-08-2016 06:18 AM
Burstbucker
Wheels/Tires
08-03-2012 09:00 AM
