Rear Sputhe, New Top Mount
Yeah, no problem! I'm still at work, but I'll take a picture as soon as I get home. The instructions weren't super helpful, though... They basically just snug up against the inside of the tubes and get locked in with jam nuts. I guess they may limit lateral movement, although the link itself does that...
There was also a threaded stud left over, which I couldn't begin to figure out...
If memory serves, that stud was some kind of installation or alignment aid. I seem to remember it saying something about removing and discarding it after something or another was complete. I could be misremembering, tho. It happens more than I'd like.
It's funny you say that... I got a new isolator, thinking it was idiotic to be up in there and not replace one of unknown age... So the first thing I did was drop the old one out. I looked at it carefully next to the new one, and they were almost identical. No signs of sagging or anything... When I started putting it all back together, I just couldn't quite get all of the holes in the new one to line up... It was super close, but no cigar. I adjusted the scissor jack endlessly, used a pry bar, etc... but no dice. Finally I put the old one back in. All of the holes lined up right away, but it wasn't easy to get the first of the two transverse bolts to start threading into the Sputhe side mount. I got it, but it was a pain.
Yes, you're right... This would be super easy if you never took the mount out. Maybe I'll replace the mount next time I have the back wheel off and there's more room.
I didn't have to touch the rear MC or the banjo fitting, but I thought I would... I could reach all of the bolts right away, but it took some fiddling to get the new bracket in past it all... But it went...
