Captain Itch Crotch Cooler with Love Jugs Mighty-Mites?
Is anyone running this combination on their late model Dyna? Pictures of the left side?
Does the Crotch Cooler block the fan intake, or rest against the fan and wear the power coat?
I’m interested in adding the Crotch Cooler as turning on the fans at a stop cooks *both* legs. With all that heat blowing off the engine the fans must be doing something!
I’m specifically looking at doing this on a 2016 Wide Glide.
replay to SDL to answer their question
From your post I'm not sure if you have the Love Jugs installed or not. Please let me know here or call me at 561-499-0974. I'm in the office now and will be on Sunday as well. - Steve,
Hey there,
I have the crotch cooler and some Ward's fans installed on my Street Bob. Similar in size to the LJ, see pics.
The crotch cooler does not interfere in any way simply blocks a bit of the heat coming from the rear cylinder and below the seat pan. When I remove the crotch cooler I can definitely tell the difference. The fans certainly blow a certain amount of air across your thigh but I think you need to manage the expectations. The fans are to cool your engine not your legs, the crotch cooler just keeps heat off the upper thigh area. It's been a good combo for me in that the two add up to help a bit overall.
Good luck!
Good luck!
robbyville (09-26-2017)
Go for it.
Roger
Sad to say, it looks like I’ll need to return my Crotch Cooler. It does not appear to work with a combination of Lucky Daves seat and Love Jugs mini fans.
First, I could not get the LD seat anywhere near installed. I even bent the front tab trying. Taking it back off and checking, there is barely any clearance between the seat and covers. Certainly not enough for that thick piece of leather to fit between. It would require drilling the front tab off the seat and shimming it so the seat could sit higher.
Second, whatever shape the LD seat is forcing the cooler to conform to shoves it right into the rear fan. It seems the LD seat is really squeezing the front leather together and pulling the outer edges forward. I think even if I modified the seat to sit higher it would still do this enough to hit the fan.
Looks like I’ll just have to deal with thigh bbq.
