Best Handlng Dyna
Campy Roadie (11-08-2017)
natedog_37 (11-10-2017)
I like riding on twisty roads where cornering clearance is VERY important. Real riders know the importance of clearance. Those extra degrees mean you can push the bike further over before things scrape, carrying greater speed through the corner
The following 3 users liked this post by Arseclown:
Received 2,189 Likes
F86 (11-09-2017)
Maybe if you lowered it 2" at both ends.
The following specifications are taken from the 2000 Harley-Davidson Dyna Owners Manual, the Harley-Davidson Motorcycles Model Year 2000 brochure and the "Standard & Sport Cruiser Comparison Chart" that can be found on the Motorcycles and Riding page.
- Wheelbase: 63.88 inches
Rake/trail: 28 degrees/4.1 inches
Overall length: 92.88 inches
Overall width: 33 inches
Road clearance: 5.75 inches
Overall height: 51.25 inches
Seat height: 27 inches
Dry weight: 619 pounds
Wet weight: 651 pounds
GVWR: 1085 pounds
Fuel Tank: 4.9 U.S. gallons (inc. 1.1 gal. reserve)
Engine type: 4-cycle, air-cooled, 45 degree V-twin
Displacement: 88 cu. in. (1450cc)
Bore: 3.75 inches
Stroke: 4 inches
Compression ratio: 9.0 to 1
Carburetor: 40mm constant velocity (CV) type
Torque: 82 ft-lbs. at 3500 rpm (at the crankshaft)
Transmission: constant mesh, 5-speed
Frame: steel double cradle
Front forks: 39mm diameter, 3-way adjustable, cartridge type
Rear shocks: gas charged, adj. for preload and compression damping
Front tire: 100/90V-19 H-D/Dunlop K 591 sport
Rear tire: 150/90V-16 H-D/Dunlop K 591 sport
Wheels: 13 spoke, black, cast aluminum alloy
Front brake: dual 11.5 inch (292mm) discs with 4-piston calipers
Rear brake: single 11.5 inch (292mm) disc with 4-piston caliper
Lean angles (right/left): 33.5/34.5 degrees
Miles per gallon (EPA): 50 hwy, 42 city
1/4 mile: 13.54 seconds at 96.48 mph
Top speed: 115 mph (approximate)
The following 2 users liked this post by maydaymike:
Campy Roadie (11-09-2017),
rideon (11-09-2017)
Well really is no perfect answer to this question .. I will answer FXDX because I love how it handled .. But I have not rode every Dyna Model to where think am qualified to say what's truly best .. Personal Choice is a factor as well when comes to Handling , Some don't care for the Super Glide with the Sportster Front End like mine has , but I like it since Added the Progressive Standard Length Front Springs.. Is no Question the Best Handling Motorcycle Regardless of make I ever owned was my FXR4 .. Was also the best looking and got the most compliments as well .. But while the FXR is included in this Section is not truly a Dyna Model .. So FXDX gets my Vote ..
