Best Handlng Dyna
#53
It's probably your fault. Did you do everything necessary to avoid this? You should've been smoking a MINIMUM of a pack a day at fourteen... In fact, with your family history, it probably should've been more than that, and probably at twelve... Think of all the cool little retro cafe bikes you would fit on now!
#54
She really wanted a HD but ended up with a used Suzuki S50 (VS800 intruder).
#56
Read the specs. They did not make them smaller. They raised most for more cornering clearance. They made them lighter from about 16 lbs to 35 lbs by using more aluminium in place of steel. And one less cam of course.
I'm 6'3" 210 and my 18 Fat Bob S is a perfect fit. Some have less rake which very slightly shortened the wheelbase.
Because of the quick steering and overall improvement in agility they may feel smaller rather than the laborious handling and mirror blurring vibration that the 15 Fat Bob that I traded in on it had.
For those that said older riders won't buy them. Thanks I'm only 77. My single desired result of having a motorcycle is that it is a riders bike. Like my XR1200, Roadster, LRS, Buell XB12XT and the older FXSTs before they lowered them.
#57
Agree on this even if not in the club .. 5'8" .. Have known several Bigger Riders that went with other makes because HD should at least have some options like a Tall Seat and way a to move the Controls to accommodate Taller Riders as an option, and not an expensive alternative to enjoy HD ..
#58
#59
Screw that. I’m hoping that they go broke for making these new shitty *** bikes. Then someone with a real sense of what Harley is buys the company and builds REAL Harleys. I’ll never give Harley another cent of mine until then.
