Best Handlng Dyna
Best Handlng Dyna
Which are the best handling Dyna? This is my opinion and what I have read.
1. Lowrider S
2. Fat Bob (second version 2014 to 17)
3. Street Bob SE (2014-16) the one with drag bar
4. Street Bob
5. Fat Bob (first version 2008-13)
6. Low Rider (newer version 2013 onwards)
7. Super Glide Sport
8. Switch Back
Give your feedback, thanks.
1. Lowrider S
4. Street Bob
8. Switch Back
The following 3 users liked this post by maydaymike:
Good suspension front and rear. Not all FXDX years had good suspension (2000 MY did not)
Forged crank with Timken left side bearing
4" stroke motor that isn't hot as hell or tries to shake itself apart. Also doesn't eat compensators
Carbed
Triple disk brakes
Mid mount controls
For the most part, no electronic geegaw BS. No linked brakes or ABS.
In 2001 HD did away with the fail prone cam position sensor
In late 2001 HD changed the rear cam bearing that was prone to failure
Dot 5 fluid that doesn't need to be changed very often
Speedo and tach up on the handlebar clamp where it belongs, not on the tank so you have to look down to see it
As far as Harleys go, not bloated with weight
Tensioners are the only knock, easily and cheaply fixable with Cyco shoes and some B148 inner cam bearings
I love my Road King, but if my garage caught fire, I'd tip it over to get my Dyna out.
The following 4 users liked this post by Campy Roadie:
maydaymike (11-08-2017)
Received 2,189 Likes
"best" is a point of contention for me. There is no best. There's best for x rider.
