Motor starts but shuts off in one second
I have a 2010 Ultra. Ran fine until I disconnected the battery for about half hour. Now every time I try to start it, it immediately shuts down. There is some code that shows up. lt looks like EIP. I have done - changed FOB battery, changed codes, 30 min procedure to reprogram it, searched for codes (all nONE)
Anyone know what is wrong?
Received 2,189 Likes
I'm new and don't know how to respond to a thread ... yet ... but I think Rustyg500 h it the nail on the head when he said the tip sensor was activated. I DID have it jacked up on one side to work under it. Never thought of it having that sensor. Now I need to know how to deactivate it.
I have not messed with anything mentioned above (I don't even know what they are). I did jack up one side to work under it. Now that you said the code was tip, it makes sense. Now how do I get it back to normal
The following pictures are of the Turn Signal/Bank Angle controller for a '12 Touring. Should be similar to your '10...maybe this will help you.
Not sure about jacking up 1 side, wouldn't the bike tip???
Also for future an Ultra is not a DYNA - might try Touring Section.
Do you have a Factory Service Manual?
DrRich (11-18-2017)
