I need to make a rear wheel alignment and belt adjustment. I don't seem to have a wrench big enough for the rear axle. Can someone please tell me what size wrench I need for a 2015 Dyna Fat Bob? I assume it's the same size on the same year Softails as well. Thank you!
Just kidding. Not sure on the size. I bought some cheap large 1inch drive socket set from harbor freight that's come in handy a few times when working on the bike. Fork tube caps and rear axle for example. If you're still in a jam tomorrow I'll run out to the garage and check what size.
36mm. I just happened to have one on hand the first time I did a tire change on my Dyna because it's the same size as the front sprocket nut on my Triumph Bonneville.
Make sure you get torque right when you are done. My nut loosened up, ended up ruining the wheel and brake caliper $$$. I bought the bike used so I have no idea who did the work.
