2001 FXDL will not idle until it's warm
I am the second owner of a (new to me) 2001 FXDL. The bike will not idle until its warm and the previous owner says it never has. The starting procedure in the manual, using the enricher, does not work and the previous owner says that the bike has “never liked to be choked”. However, turn the throttle a couple of times, hit the starter, and it will start every time…and as long as you stand there for a couple minutes ready to crack the throttle you can keep it running. After 2 or 3 minutes of babying, it will set there and idle all day at ~1,000 RPM. If you pull the enricher out even a little during the warm up period it will die. The bike is carbureted with no engine modifications and has 12,850 miles on it (hardly ridden). I took it to a local Harley shop and they “tuned it up” and rebuilt the carburetor…but it still won't idle. The mechanic says everything checks out fine and that at this point he doesn’t know what else to do. He suggests that since it’s just a couple minutes in the beginning, I just deal with it.
Anyone else had this issue?
Received 4,281 Likes
Same procedure since day 1 on my '03 FXD (80,000 miles)...a little choke and three turns on the throttle before hitting the starter button.
Jet it (adjust the needle) richer and that will cause the bike to warm up faster.In a colder climate its not unusual for the bike to need a 20 second choke engaged warm up period .These bikes are jetted *EXTREMELY LEAN* from the factory to comply with the dumb EPA requirements and it's probably STILL jetted way too lean after you let an H-D dealership "adjust it" , so it's not an issue if you can find a qualified tech or shop to adjust the carburetor alot richer properly. Or Buy the Shop manual and tackle the job yourself-its a 15 minute job and we do em all the time .
Cold air is more dense which requires more fuel to mix at that good ole 13:1 ratio.
normally id agree but if it's dying with the choke pulled I wouldn't think it's a lean condition. +1 on the stage 1 and intake/exhaust though
JayStronghawk (11-27-2017)
First thing to do is put a Sporty jet needle H.D.# 27094-88 [still available at your local dealer for approx. $10] in the carb. There is a complete guide somewhere on this forum, but basically you're partially removing your carb. and drilling out a small blank cover and unscrewing the o.e.m. jet needle You refit the 'new' one, unscrew it 2 1/2 turns and away you go...b.
Nick - It only smokes if I pull out the enricher while its running or pulled out the enricher while initially turning it over....otherwise no smoke. I appreciate everyone's comments. Since pulling out the choke even a little kills it, I don't think its a lean condition as others have mentioned. Thanks All.
I recently bought a 2001 FXDL with 3,100 miles on it. It is my first bike with a carb. It seems to run fine with the enricher on for cold starts but I had a weird issue the other day where the bike would die at idle after a few minutes of riding. I had to rev it at stops just to prevent it from happening. I haven't had that same issue since.
