Whats this plug for then?
Old 02-17-2018, 10:24 AM
rossWG's Avatar
rossWG
rossWG is offline
Default Whats this plug for then?
Cleaning my bike today after the 1st ride of the year, i noticed this plug unconnected. Rode the bike, nothing appeared not to work.
Any ideas what it is for?
Old 02-17-2018, 10:35 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
It looks like the active exhaust valve connector; it's used on some EU bikes. But I guess not in Scotland Like the active intake solenoid connector behind the A/C, tuck it up and out of the way...
rossWG (02-17-2018)
Old 02-17-2018, 10:41 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
or it could go there. *guessing*
The following 4 users liked this post by cvaria:
F86 (04-30-2018), Flinter (05-07-2018), rossWG (02-17-2018), TinCupChalice (02-17-2018)
Old 02-17-2018, 10:42 AM
rossWG's Avatar
rossWG
rossWG is offline
Old 02-17-2018, 10:50 AM
TinCupChalice
Originally Posted by rossWG
my fork extensions have just come thru customs and will arrive next week
but i think i have not thought it thru. not sure if there is enough slack in the ABS cable or brake line from the lower head manifold
fitting the arlen ness big brake kit at the same time so that may help the brake line, but not the abs cable
Check out what Cvaria has posted an image of; that might be the protective cap mounted for the active exhaust connector to plug in to and be protected from the elements. On my '13 that connector has a cap, but it's hanging loose so I've got it tucked up under the seat.
You will get some brake line slack with the Big Brake caliper adapter; it might be enough <hope!> With my non-ABS and the caliper adapter I've got enough brake line to go another 2" in fork tube length but with you being ABS that length of brake line from the manifold might be a problem.
I wasn't trying to get an image of the caliper adapter in this shot, but you can see when the brake line ends up positioned with the caliper adapter.
Keep us posted!
rossWG (02-17-2018)
Old 02-18-2018, 12:31 PM
Krazy8s's Avatar
Krazy8s
Krazy8s is offline
Old 04-30-2018, 09:59 AM
rossWG's Avatar
rossWG
rossWG is offline
Another plug detached, i cant workout from?
Cannot remember detaching it
Old 04-30-2018, 10:34 AM
O-Town D's Avatar
O-Town D
O-Town D is offline
[I][QUOTE=rossWG;17320154]Another plug detached, i cant workout from?
On US bikes, that plug for the Actv Exh is unneeded; it is capped off and simply clipped onto the back of the A/C plate. On the EU bike with Actv Exh I would think there would be a matching receptacle for it somewhere nearby.....
TinCupChalice (04-30-2018)
Old 04-30-2018, 02:13 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
If the wiring colors are Red/Green and Light Green/Violet it's the connector for the AIS (Air Intake System). If istalled the connector should fit in the backplate of the intake.
Check out this thread with images on the same subject.
rossWG (04-30-2018)
Old 04-30-2018, 02:20 PM
FXD2003Rider
What colors do the wiring to this plug have?
Quick Reply: Whats this plug for then?
