Synthetic or conventional oil for older 04 dyna low rider
Haha, if a shop told me synthetic leaks over a conventional oil........ Id find another shop......
Synthetic will give you more miles between changes. If thats what u want is extended maintenance, then go synthetic. Otherwise youre fine either way. I doubt HD states running synthetic in that bike.
Interesting that they would say that when most shops spin the SYN and tell you how much better it is and then charge you $15-$25 more when the product cost them $5-$6 more. (Guess the caps are harder to screw off and causes them more work)
When your 04 was built, unless someone has messed with it, Harley's had marking their spot way behind them.
Even so, if it leaks SYN, it is going to leak regular oil. There is not that much magic in it. A weep is not a real leak but if it drips, it needs a new gasket or seal.
Leftcoaster
06-18-2013 09:10 PM
