need to raise frontend
Old 03-03-2018, 10:29 PM
scoop_fraser's Avatar
scoop_fraser
scoop_fraser is offline
Default need to raise frontend
I've got a 2000 FXD that I have installed 14" Ohlins on the rear. Will I possible run into issues with the new rake/trail geometry? Is there a way increase the height of your front end? I've got Works Performance fork cartridge inserts, fwiw.
Thanks,
Scoop
Old 03-03-2018, 11:35 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Drop the forks in the trees
Longer forks (CCE) (or HD FXDWG forks)
Larger tire diameter
Rake & Trail calculator
Old 03-03-2018, 11:39 PM
Yamaharley's Avatar
Yamaharley
Yamaharley is offline
I would put 2 inch over tubes on the front and call it a day. You're at plus 1.5 on the rear so 2 over up front would make it sit really nice.
Old 03-04-2018, 11:32 AM
scoop_fraser
Would the cartridges that I have work in the longer tubes? Could I just cut some 2" longer pre-load spacers?
Thanks much.
Old 03-04-2018, 04:35 PM
abez's Avatar
abez
abez is offline
get some 39mm FXDWG fork tubes. they are +2.x" over. cartridges will work.
Old 03-04-2018, 05:50 PM
cggorman's Avatar
cggorman
cggorman is offline
Wide Glides are 41.
I.forgot about the 39s. CCE can make whatever, tho.
Eightball52
03-18-2022 01:28 PM
Gladiator72
10-10-2012 09:01 PM
Bobbed Out
07-23-2009 08:15 PM
Trichey
07-23-2009 11:36 AM
Quick Reply: need to raise frontend
