What pulley bolts?
Old 06-25-2019, 03:14 PM
GREENOHAWK69's Avatar
GREENOHAWK69
GREENOHAWK69 is offline
What does ther term "waist" mean here?
  #52
Old 06-25-2019, 10:42 PM
Blue Bob's Avatar
Blue Bob
Blue Bob is offline
Received 1,013 Likes on 602 Posts
The area between the head and the threads is smaller in dia. than the major thread dia. ie: 7/16" .437"
  #53
Old 06-26-2019, 10:23 AM
John CC's Avatar
John CC
John CC is offline
Bottom line, I think, is that bolts are not supposed to be loaded in shear. They provide clamping force and the friction between the hub and pulley is supposed to transfer the torque. Once they are loaded in shear, or once some of them loose their tension, it's all over...
  #54
Old 04-02-2020, 07:58 PM
dynaholic77's Avatar
dynaholic77
dynaholic77 is offline
Originally Posted by Stunna16
Bill lock R is not going to fix the problem at hand here.
They definitely don't fix anything
Max Headflow (04-05-2020)
  #55
Old 04-07-2020, 02:51 AM
Tall Timber's Avatar
Tall Timber
Tall Timber is offline
Technically the bolts never backed out........ technically.
  #56
Old 05-19-2020, 11:08 PM
dynaholic77
Well here goes hoping someone still checks this out. Bolt problem,,blag blah so fast forward to solution.
I picked up the arp bolts I found them local for only $8/bolt, washers the thin grade 8 bc more shoulder in the bolt hole,,, the bushings I'm not sure so asking blue bob,,,my pulley is 1.25" my bolts are 2.75" I've found bronze sleeves at 1"x 7/16 i.o. and od of 9/16 and also a cut to length thata 7/16 x 5/8 ....anyway hope you see this bob if not thanks for the info
  #57
Old 05-20-2020, 04:53 AM
joe40x's Avatar
joe40x
joe40x is offline
Harley would not have spent extra money on .125 thick washers if they were not needed. The bolt clamps the washer. The washer clamps the pulley
fxr_jp (09-10-2022)
  #58
Old 05-20-2020, 08:23 AM
Blue Bob's Avatar
Blue Bob
Blue Bob is offline
Judging by the direction your going you understand that the clamping force between two aluminum surfaces is not designed to handle the forces of accelerating and deaccelerating a 700lb bike. It's the combined action of clamping and the bolts driving just as in an automobile application.
The bores in the pulley are just too big and the driving portion of the bolt (shoulder ) and the exposed threads creats a stress riser situation.
Sleeving as you look to be doing I feel is the proper approach.
The bronze is much harder than the aluminum so good there. Just make sure the wall thickness is not large enough to compromise the pully integrity when you bore the pulley.
fxr_jp (09-10-2022)
  #59
Old 05-20-2020, 09:47 AM
MRFREEZE57's Avatar
MRFREEZE57
MRFREEZE57 is offline
Received 4,046 Likes on 1,897 Posts
It seems that the rear wheel and sprocket should have splines for the high torque application, though would add to the cost in extra machining.
slight subject change, how many miles do some of you have on your belt and rear pulley? am approaching 52k miles, belt looks ok, rear pulley appears some chrome gone in the crotch of the teeth.
weezl
06-24-2019 11:51 AM
Stinger1
05-31-2019 10:06 AM
izzyryder
02-07-2015 11:21 AM
paulies 07
03-22-2012 02:04 PM
jm04
08-24-2009 04:07 PM
Quick Reply: What pulley bolts?
