Did I just end up with a LEMON ?
Old 05-02-2018, 05:41 PM
WKRTX's Avatar
WKRTX
WKRTX is offline
6th Gear
Default Did I just end up with a LEMON ?
I bought in 2017 a used FLD 18,285 103+
Since then I have dealt with one thing after another
Current issues are
Oil leaking from the air filter & switches going out
The L turn signal & H beam lights went out about 6 months after I bought it
The oil leaking started about 8 months ago
I took it in to the mechanic who worked on it for the other owner & was told it's normal ??
Now the LH Switch Module has decided I need all 3 lights on not just the low beam
This is my 1st HD to own & not making a good impression on me about owning one
Old 05-02-2018, 06:03 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
so get rid of it....
Indian has bikes for you
Old 05-02-2018, 06:14 PM
WKRTX's Avatar
WKRTX
WKRTX is offline
6th Gear
Old 05-02-2018, 06:22 PM
WKRTX's Avatar
WKRTX
WKRTX is offline
6th Gear
Ain't an indian motorcycle fan
Just I always thought that Harleys were worth owning so I found one, but it hasn't lived up to the "Made In America" idea ??
I have spent way more $$$$ on repairs on my FLD then any other motorcycles I have owned
Too old for a crotch rocket again
The performance (power) has been what I was wanting just things on it seem to fall a part & the mechanic who worked on it for the previous owner isn't much help
So I thought maybe I might find some answers in this site ?
Old 05-02-2018, 06:25 PM
Fatbob bagger's Avatar
Fatbob bagger
Fatbob bagger is offline
Depending on mileage you should still have warranty
Old 05-02-2018, 06:27 PM
WKRTX's Avatar
WKRTX
WKRTX is offline
6th Gear
This is a close up of the oil leak
It has the SE system on it
Old 05-02-2018, 06:31 PM
Jr177's Avatar
Jr177
Jr177 is offline
Find a new mechanic.
Old 05-02-2018, 06:32 PM
WKRTX's Avatar
WKRTX
WKRTX is offline
6th Gear
I'm the 2nd owner & 32,000 it's a 2012 FLD so bet the warranty is long gone by now
Had 18,285 when I bought it 03/2017
Old 05-02-2018, 06:36 PM
WKRTX's Avatar
WKRTX
WKRTX is offline
6th Gear
That is on the list of trying before I put it back on the market
Hate to sell it, but just ain't rich enough to afford to keep it if things keep going
The new LH Switch Module is $286 from my local dealership
To replace the strip with the lights form H beam turn signals oil etc is like $300
Not spending $300 just to replace the L turn & H beam lights bulbs
Old 05-02-2018, 06:45 PM
DynaKid94's Avatar
DynaKid94
DynaKid94 is offline
$300 to change lightbulbs?? I hope I'm reading that wrong...
Could be wrong on this but oil in the air cleaner isn't unusual, depending on your breather setup...
Guarantee you can find a used switch housing on ebay and such for cheaper than buying a brand new part at the dealer, but I'd be more concerned about any suspect wiring done by the previous owner and this "mechanic"...aftermarket handlebars
Sounds to me like you bought a bike with a sketchy past and a sketchy mechanic...cut your losses and pick yourself up a better bike...
Quick Reply: Did I just end up with a LEMON ?
