How much air pressure
Old May 10, 2018 | 07:17 PM
GWC68's Avatar
GWC68
Default How much air pressure
So I tried searching and either suck at it or my phone sucks.
I was wondering what people are running for air pressure on the Dynas with stock tires ?
Mines a 16 LR
Thanks for any help.
Old May 10, 2018 | 07:32 PM
user 9370's Avatar
user 9370
If I remember, the manual says 40 rear/30 front
Ray
Old May 10, 2018 | 07:35 PM
user 9370's Avatar
user 9370
Found this.....
2016 Harley-Davidson FXDL Dyna Low Rider Motorcycle Tire Pressure
Recommended tire pressure for 2016 Harley-Davidson FXDL Dyna Low Rider motorcycle tires. Check 2016 Harley-Davidson FXDL Dyna Low Rider motorcycle tire pressure to maintain proper 2016 Harley-Davidson FXDL Dyna Low Rider motorcycle tire inflation.Model YearTire SizeTire Pressure2016F: 100/90-19
R: 160/70-17F: 30 psi
R: 41 psi
Old May 10, 2018 | 07:44 PM
GWC68's Avatar
GWC68
Thanks for that info, I was wonder as well If anyone was running more or less pressure tp alter the handling or if that would even be possible.
Old May 10, 2018 | 07:56 PM
bigbadpoppa's Avatar
bigbadpoppa
Most users will run slightly lower if they ride aggressively (larger contact patch) while some may run higher if they want longevity.
Old May 10, 2018 | 08:23 PM
crusader1xxx's Avatar
crusader1xxx
A shop manual is your friend...buy one.
Old May 10, 2018 | 08:32 PM
nevil's Avatar
nevil
That information (and more) is all in your owner's manual.
But more to the point, what kind of handling issues are you having?
Old May 10, 2018 | 08:39 PM
GWC68's Avatar
GWC68
I was just wondering if anybody was doing this to change handling or if a slight change would do nothing, or if everyone was just running the recomended air pressure.
Not having any problems.
Old May 10, 2018 | 09:03 PM
bigbadpoppa
Tire pressures make a difference. The manual is a starting point and a good baseline. From there u can make the adjustments depending on your riding style. Tons of articles out there regarding tire pressure.
Old May 10, 2018 | 09:11 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Personally, my 07 Dyna with Michilin Commander II's likes 32/38 psi. Handling is crisp & precise. I found this out by experimenting with the air pressure. Each bike setup is different, such as saddlebags, rider weight, big touring seat or solo seat. One thing to remember - do NOT go lower than what HD "suggest" you tire air pressure should be.
