1995 Heritage Evo engine starter ring & starter gear breakage have replaced 4 in 12,000 miles! What could be causing this? Engine has stock pistons & Screaming Eagle heads 9.0 comptrssion ratio!
1995 Heritage FLSTN stock pistons & Screaming Eagle Heads! Have replaces starter ring & starter pinion gear 4 times in last 12,000 miles, any ideas as to what is causing this failure.
Received 4,284 Likes
Welcome to the forum and check the EVO board for some help with your Evo.
Here's a suggestion, condense the problem in the new thread block, i.e " Going through starter and ring gears, 4 in 12K miles" then in the next box describe the problem, what you have done and include year of bike , model etc. Again, welcome.
