First Steps in Improving Performance
Over winter I want to start on my performance enhancements on my 2008 Street Bob. I think that my initial steps will be simple bolt on items: air filter, exhaust and a tuner.
On the air filter I am thinking about something like the Arlen Ness Inverted Sucker. On the exhaust I am not really sure, but will definitely be a 2 into 1 (such as a Bassani Road Rage) as I want to maximize mid range torque and not top end power. I don't think that the air cleaner or header can be put on without a tuner.
On the tuner I really have no idea. Ultimately I will do some more engine mods. Not sure what, but probably will not be anything crazy - bump displacement up to 103, increase compression, possibly minor head work & a cam. I would definitely want to get a tuner that would be able to handle these future mods.
Any suggestions on components for me to start considering would be appreciated!
JayStronghawk (10-31-2018)
Performance upgrades are not only motor centric - but could (and should) include handling / suspension/ braking
That said - motor upgrades are a slippery slope...
Do one - 5 more are required to make it reliable
Do one - 10 more are required because now... you want more
Don't get me wrong - I've upgraded the living **** out of my dyna - and love it
Just go into this with a plan..., and don't deviate - otherwise plan (and be prepared) to spend a considerable amount to get results worth a ****
Ghost
Think of an orchestra, not one member.
The whole thing is symbiotic.
A freekin air filter is going to do nothing for you.
You need a cam-
then you need your heads worked, then you need fuel, then you need exhaust, and then and then.
I ALWAYS say
write dwn your end goal and march that pathway or else ylou will just throw parts at it.
You CANT *bolt on Horsepower.If you really could everyone would be doing it.
*turbo you can.
You need a cam-
I ALWAYS say
*turbo you can.
You need a cam-
I ALWAYS say
*turbo you can.
You need a cam-
I ALWAYS say
*turbo you can.
Kingglide549 (10-25-2018)
