Pictures of battery tender pigtail attachment wanted
Man, that is SWEET!
Is that a legit bulkhead mount, or did you glue in the stock pigtail? Did I mention how clean that looks? Dang straight!
Mine is routed through the positive cable port in the battery box and drapes down on top of the transmission. The PO set it up thus way. It doesn't look bad, so I've never fooled with it.
SixDD (11-03-2018)
Dont own a Dyna but used to do this on my old Fatboy - run the pigtail out the back underside of the seat, then you can plug in one of these and a car phone charger and charge your phone in your saddlebag when riding. Super useful on a long trip.
They make USB ones too depending on the phone charger you have.
YMMV
YMMV
SixDD (11-03-2018)
[QUOTE=SoGA;17801253]Man, that is SWEET!
Its pressure fit against the coil mount. The 12 point mounting bolts have slots so I put pressure to the right and it pinches the plug. It works but not perfect.
Location: Depends on who wants to know.........and why.
Received 1,901 Likes
SixDD (11-05-2018)
SixDD (11-05-2018)
That would be great, IF you had already moved your coil to another location. If your coil is in that position, though, you can't do that. However, there's a guy who is making metal mounts for cigarette lighter/power plugs to bolt under the coil, and a little toward the front of it. It's a metal bracket that just bolts up under the coil, with a larger piece underneath that has a hole for the power plug to mount into. Here's a shot of the one on mine:
With Plexi, though, you could do something similar to what you did for your battery tender plug, but have it directly under the coil, or you could make one that has holes for both the battery tender plug and a power plug. I might cut a notch in the back side of this metal plate, but "keyed" to slip the wire from my battery tender in, and hold it there.
