Bad motor mount ? How to tell.
I have read that and I wont buy a stock one but my extended warranty should replace it for free , just really wanting to know how to tell if it was bad since I had not seen a bad one in person.
I did not know if it would crack or fall apart or sag like was stated, or what kind of vibration it cause.
I will let warranty fix this one and next time I will put a Predator mount in it.
Thanks.
Thanks.
The stock mounts have a tendency to collapse. There is supposed to be a gap between the top of the mount and the frame. If there isn't, it has collapsed. Had one collapse two weeks after I installed it. The Predator mount is a band aid and an expensive one, and many have found no difference.. The root cause is most likely a bad crank/flywheel. $3000 to replace.
This was going to be my next question , could this be that my crank " fly wheels spun" and is now out of balance ? Because after thinking about it I would say its a shake out of balance feel more than a vibrating feeling.
so is replacing the crank something Harley will warrenty or when I go in there are they just going to tell me its normal, just kinda wondering what to expect.
Going to haft to do more searches on this I guess.
Can you observe the engine visibly shaking a lot more than it used to, or do you just feel a lot more vibration through the bike while riding? If so, it may be the pretty common sidestand issue... A worn (but serviceable) mount can let the engine move back in the frame slightly, causing the sidestand pin in the frame crossmember to press against the crankcase. This basically transfers all engine vibration directly into the frame.
