Bad motor mount ? How to tell.
Its a hard vibration more of a shaking , starts close to 2,000 rpms and feel like it stop over 3500 rpms and is there when you lift off the throttle.
only time I dont feel it is at idle or just off idle. When I started it after work and took off it was one of those "what the hell" things.
This is my 4th Harley with all the previous ones being Sporties, 1 1200 and 2 1000cc and I never had one feel like this one does.
I will check out the motor mount more and see if everything else is right and nothing is hitting but will take it in to the shop Monday if I can and go from there if I cant find anything else.
JayStronghawk (03-23-2019)
I really did not mean to suggest the Dyna and Sporty were the same just stating I believe I know what normal vibrations on a Harley are like..lol
Its not a mirror buzzing vibration or anything like that its more of a shaking type just hard to explain but its really pronounced under throttle and after let off the throttle untill it returns to idle is bad.
I thought I might get off work early and was going to take it in but it will haft to wait untill Monday now but I will look at everything you guys are talking about and see what it looks like tomorrow.
Thanks
Thanks
Went out and looked at the mount again and took some better pictures, it also looks like it is setting lower than yesterday, I grabbed a feeler gauge and could just barely push it through.
so setting on the rubber is the problem right, and I am sure when its revving its really hitting.
So if I trim the top of the rubber off it by alrights should not vibrate anymore and then I can decide to have the dealer throw a stock mount on it or go buy a Predator mount.
That's not good. Is that dark crescent on the steel cross piece above the isolator bump stop a shadow or where the dirt was rubbed off by the rubber?
A trim should help, but that isolator is on the way out.
IMO, Predator won't isolate much, if any, better than stock but it should last longer.
Cggorman mentioned shimming the mount, and that sounds like a good suggestion (in conjunction with trimming the "bump"). You may want to peruse this thread:
https://www.hdforums.com/forum/dyna-...today-wow.html
