Bike turns over but won't start.
I have a 1991 FXR it had been locked away for a couple of years i did the fuel oil etc charged the battery and bang it started straight up. I rode it and when i stopped it wouldn't start, then after persevering it started. It did this for a couple of days and then i took it for a ride to a job interview as i have no other transport atm, dreading it not starting but it started straight up i rode home about 30min parked it not a prob it ran well. The next day i went to start it and it wouldn't start. I checked wires connecting to the battery and replaced the connectors on a couple of them, still not firing, took the plugs out gave them a clean checked for spark on the back cylinder and the bike started and the plug had spark. Put the plug back in bike cranks but no start, took the plug out and again it started. I put it back in a mate came over i went to show him pulled the plug out cranked it the bike didn't start this time and the plug had no spark. I took both plugs and put them in the car lead and the both tested fine with a bright blue spark put them back in the bike and nothing it cranks but wont start. Any advise would be greatly appreciated TIA. AL.
Here is a link to the Harley Electrical Troubleshooting Guide for your bike. If your ignition is stock you will notice on page 6 of 276 (page 2) the diagram for your system. On that page and the following page, it notes the grounds to check. I would start there. Then if you still have no spark move through the diagnostic procedure described for the balance of the system.
I would also double check that you are getting fuel into and from the carburetor as the bike was sitting and it is possible that debris eventually found its way into the carb?
https://serviceinfo.harley-davidson.com/sip/content/document/view?id=5524¶meters=highlight%3D1991+Electrica l
https://serviceinfo.harley-davidson....991+Electrical
MISFIRE OR INTERMITTENT OPERATION Field experience has shown that popping back through the carburetor, misfiring, and intermittent failure (especially after the engine gets hot) are usually not caused by electrical problems within the HI-4. Carburetor problems, fouled spark plugs, coil failure, and loose wire harness connections are the most common culprits.
http://www.nightrider.com/biketech/d..._hi4_race2.pdf
Thanks mmesa005, Your other link had some great to know bits in it i will look at this also and i thank everyone who has some input for my problem, As i am only new on this site i am still working out the basics on how to use it so if my comment end up being a post or it looks like i am not responding to something, it's not because i'm ignorant but more like i'm learning Cheers for your help just the same. By the way nice ride u have there mmesa005
mmesa005 (11-17-2018)
AFORAL (11-19-2018)
AFORAL (11-19-2018)
