Noticed a leak today, not sure if urgent
Hey I noticed the below leak after riding today for about four hours, I checked the oil and it doesn’t look low, should I be immediately concerned? Dyna has apx 10,000 mi and I was going to replace the oil soon anyway so just trying to determine if I need to start researching how to (insert whatever is leaking here)
Probably fine to ride around for a bit. Keep an eye on it and keep it wiped down.
Did the dealer put the forwards on for ya? Then they need to replace the tower gasket. Should be warranted. If you put the forwards on easy enough fix. I bet when the primary was reassembled that tower gasket was a bit askew.
This. I also used the freeze plugs on both inner and out cases after discovering the same leak, worked like a charm. I even tried JUST replaced the tower gasket to no avail prior to using the freeze plugs. Learn from my mistake, use the freeze plugs. I also used some sealant around the plugs to be extra sure. Didn't really feel like going in there for a third time.
