Flywheel Runout over .020.
Also is the reading TIR or actual run out. I personal would expect the mechanic to show me the testing for a 1500.00 crank. Take him 3 minutes to set your mind at ease that your not being hoodwinked. Especially, after I'm sure you told them several other shops have inspected and charged you.
I have been through a GS1000 crank nightmare. Had the crank trued and welded and shame on me I did not check it. Completely assembled bike, cranked on the first try only to hear the same roar from the bottom end. It took one year to save money, acquire a new unused crank from Yoshimura, had it trued and welded by a pro stock racer in Conyers Ga. I checked every journal this time, .002 TIR
If the pin is good the assembly can be trued, then pinned and welded. It will not slip again unless its abused.
