1996 wide glide general question
Old 01-04-2019, 05:21 AM
Im2cool4u9009's Avatar
Im2cool4u9009
Im2cool4u9009 is offline
Default 1996 wide glide general question
Hello I am going to be changing my grips and clutch and brake levers I know that someone told me to lube the pins on the handles up and lube clutch cable what do I use? Is their a certain lube? Also is their a special spray for the rubber boots for the idle and throttle cables and clutch adjuster boot too keep it from turning inside out? Thanks guys
Old 01-04-2019, 06:11 AM
FreedomRider's Avatar
FreedomRider
FreedomRider is offline
For the cable I use the light oil that comes in the pin oiler you can get from HD … WD40 or any good lube will work for the pivot pins … you can also use WD to make the rubber boots easier to slide …
be careful when changing the front brake lever … it is very easy to break the front brake light switch unless you shim the lever before removing or loosening the front master cylinder … I use a penny and it works fine
Old 01-04-2019, 11:08 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
I use bearing grease on the pivots and dri-slide on the cables.
crusader1xxx (01-04-2019)
Old 01-04-2019, 01:04 PM
Im2cool4u9009
yeah I know I ushually use a piece of cardboard to chim it
Old 01-04-2019, 02:32 PM
Im2cool4u9009
Y
our guys think liquid wrench will work for both ? They also have white lithium grease spray. Thanks
Old 01-04-2019, 02:34 PM
Im2cool4u9009
Or use liquid wrench on the lines and there is a Lucas white lithium grease actual like grease not spray on. For the pivots? Thanks
Old 01-04-2019, 02:37 PM
Im2cool4u9009
or they have this sorry for all the post guys last time I went looking for this stuff their was like 3 items now blaster and Lucas make everything haha
Old 01-04-2019, 09:51 PM
crusader1xxx's Avatar
crusader1xxx
crusader1xxx is offline
i do the exact same on the pins...and the oil pen from HD for the cables, I use the grease on the clutch adjusting nuts as well.
Whiskyjock
02-03-2019 01:59 PM
grueter
07-16-2012 05:32 PM
Kess
General Topics/Tech Tips
11
05-24-2012 10:09 PM
hoethree
03-17-2011 01:07 AM
HDDyna2006
09-11-2008 07:13 PM
Quick Reply: 1996 wide glide general question
