FXDX Winter Suspension Project
#91
Hi Jake - I'm happy to measure anything helpful... But I probably won't remove the original shocks until I have the front back together (hopefully not too much longer). Just let me know exactly what you need.
#92
Not sure if it's helpful, but the stock lower bolt is 1/2-20 x 2-1/4 (grade 5)
For non-stock applications, actual required length will vary depending on spacers, washers, and shock eyelet width.
Howard sends the necessary spacers and bushings with his Ohlins kits so that the stock hardware can be re-used.
#93
#94
#97
#99
#100
