TC88 Cam Chest DIY and Final Decisions
I will be installing a baisley spring when I have mine apart. I'll check how the plunger is doing while I'm at it.
So, been getting new toys in the mail. SS509 cams came, SS premium lifters, cyco pads and gasket kit (has some stuff the cam kit is missing since I am going through the rockers), got the rockout rocker inserts, and also got studs/12 point nuts for the holes that like to strip for the cam plate. Waiting on inner bearing puller. Might order oil alignment pins and cam/crank locking tool. Understand I might not need them, but they are pretty cheap for piece of mind.
Going to drill oil drain holes when I'm in the rocker boxes. I guess most people just grease up a .125" big and drill them on the bike?
Also, dont have a factory manual but a buddy has one. Decided to look on ebay to see if I could find one just to have, but the cheap beat ones are still around 90 bucks. Found a guy selling the digital copies for 10 bucks. He ships you a CD with it on there, but also sends you a link to a digital download which I wasnt even expecting. Pretty cool. Will have to look at it on my phone or a tablet, but not that bad.
Did some reading through the manual, I think I got this.
Finally got this done! Fired her up yesterday. Not a bad job, took some time being my first go through. IF anyone needs the cam bearing install tools, I am more than happy to rent them out for cheap. Made the inner cam bearings an easy job. Also have the cam gear locking tool and oil pump alignment pins that I could ship with it.
Only bummer is i did strip one of the cam COVER bolts, little bummed about that but found a longer bolt that seemed to grab well, although I didnt go to torque spec on it. Should be fine.
Installed the rocker lockers, and the basiley spring, still hear some clacking at mid rpm range, not sure what is going on there ( used stock pushrods so no adjustment there to be had).
My main concern now is if I need jets for the carb or not. The plugs were more white when I pulled them, so figured I would need some jets but apparently looking at the plugs isnt the best method these days?? Not really sure how to go about that. Supposedly my bike had the sportster needle installed by the PO when he put the K&N and T header on, but really not too sure. Any input?
pegskraper
07-19-2016 04:01 PM
