Ball joint mirror
How do I tighten this or take it apart ? I hear rattling inside the mirror. TIA |
https://cimg6.ibsrv.net/gimg/www.hdf...de0f8c0b0.jpeg
Both screws missing |
Just get new ones. Not worth dissecting it. |
Ah...Install the screws?
Originally Posted by joe40x
(Post 17977437)
good one genius. The screws will not go back in. There is a rattling inside there and thats why I’m here asking how to fix that |
Get some loctite (not the standard blue or red, but thinner stuff like bearing retaining compound). Clean and dry the ball joint w/ alcohol. Drip a couple of drops in when mirror is facing down. Quickly mount the mirror to bike and adjust. Do not ride until after it has a couple of hours to set up and then do not adjust/re-adjust mirrors.
Buy a new one or put some self tapping screws w/ loctite in that one and call it good. CL is an excellent source for mirrors.
Originally Posted by Jc1287
(Post 17977573)
Originally Posted by Nomadmax
(Post 17977755)
When you need help, I've found it's usually best to be gracious. The above poster had know way of knowing if you knew there were supposed to be screws there. We get all kinds here, some of which, are not mechanical at all. This is a neighborhood just like any other. Many have come here, rubbed folks the wrong way and then only heard crickets when they had more questions. That, you didn't ask for, so take it for what it's worth to you. Hmm ... was Negative Sarcasm involved with the post in question? ;) ("Negative Sarcasm" ... that may be redundant ... somewhat like "Irregardless" :)) . |
(Post 17977771)
https://www.hdforums.com/forum/images/icons/icon14.gif
(Post 17977573)
good one genius. The screws will not go back in. There is a rattling inside there and thats why I’m here asking how to fix that Ok OP It's easy. Plan A. Lay back in your recliner. Put the mirror side toward the ceiling and gently shake it around until the piece inside reappears. Line up the holes and install the bolts using blue loctite. This will take some time, patience and can be rather trying on the nerves. After an hour or two of this method, if you have no success, go to Plan B Plan B SC&R(Shit can & Replace) They're not all that expensive and after Plan A, you'll be ready to start barking at the moon. Have a beer, chill out! We're a little ornery around here. But happy to help! You will get your balls busted though. |
© 2024 MH Sub I, LLC dba Internet Brands
