2003 FXD Not Starting; Video Inside
Hello all, I've got a 2003 FXD that won't seem to crank over and I suspect the starter is toast. The battery has a full charge and multiple cranks won't get the jackshaft to connect to the primary. Is this indicative of a dying starter or is it an issue with the starter clutch?
Video Below:
Any and all suggestions welcome, thanks!
Video Below:
Well, threw on the new starter and worked like a charm. I've linked it below in case anybody wanted to know what I used. Seems high quality, came with 2 different jack shaft lengths and an extra solenoid cover if I wanted a chrome look.
Next I've got to order some outer primary gaskets, a new lock washer for the jackshaft, and then I should be good to get it running. Still need to sort out an oil leak, but i'll save that for another thread.,
Cheers boys.
https://www.ebay.com/itm/HARLEY-STAR...72.m2749.l2649
Cheers boys.
Lons 77
11
08-30-2008 01:46 PM
