Tank Lift
I did the front only for the looks. I had to remove it do to the earlier split tank design and there being fuel in the tank I couldn't use because of the angle.
It does improve air flow that increases cooling. Raising the rear helps more but I wouldn't go as high because the seat and rear of the tank won't "flow".
It also aids in the cleaning of the top of the rocker boxes.
i have 2" front and 1" rear, via a drill into the lugs. It is a tight fit with the existing seat right enough
i like the look, and indeed the cleaning is possible for my 'plates of meat'
would suppose the engine will cool quicker on the move
Also as a side, i have the DKCustoms coil relocation which helps even more the airflow at the rear
Its diificult to tell. Many say that the gauges are not very accurate.
i have got down to 18 miles remaining on the gauge, before a refuel
the feeder connection is fairly rear on the left, so i wouldnt think the new induced angle has much effect
