2003 FXD Oil Leak
2003 FXD Oil Leak
I've got a pretty severe oil leak coming from what I suspect are the exhaust bracket bolts after putting on my thunderheader. Before the thunderheader and bracket I was running a V&H Big shots staggered that didn't mount up through the transmission cover.
For those unfamiliar, the thunderheader exhaust bracket has 3 bolts that line up through the bearing housing (Harley Part # 35250-90D). I've noticed the oil seeping through the gasket behind the bearing housing, and I suspect that it failed after the bolts were installed. I've also heard that you need to run a longer bolt a at the end of the bracket (picture below), this is where I've found the majority of the oil falling through. It's gotten all over my rear wheels, brake, and exhaust. Can't take it any more
Oil leak is coming from behind this bolt.
How do I get to behind bearing housing and replace the gasket (Part # 35653-98A*)? Do I need to remove the bearings/oil seals in the transmission to get to those gaskets? Pic below.
Part Diagram (# 29 I need to get to)
Any help appreciated boys.
You're not going to get that trap door out without removing the gearset. The chrome cover will come off easily but not the trap door. The hole above that bolt should have a bolt in it and those Allen bolts for the bracket should have washers on them.
That being said.... you should take the bolts to your hardware store and get longer ones. Put them back in pretty tight and I bet your leak will stop
The following 2 users liked this post by misfitJason:
crusader1xxx (02-11-2019),
SeaClassExpert (02-10-2019)
Dr. Tiki
2014-2023 Touring Models
05-24-2018 04:16 PM
ronherman
09-03-2013 07:31 PM
