stock throttle body size on a 2011 Dyna?
Thanks for the information. If im running a 107 kit with head work , woods 888 cams, high flow air filter, bassani exhaust, woods lifters and pushrod. I may just buy a bigger throttle body, high flow injectors and either keep my woods 888 cams or bump up to woods tw-999-6A cams. Although the Woods 888 cams seem to keep going up until 6k rpms until they drop off. Right now Im running cylinders with pistons that are 10;2;1 compression. I may consider running cylinders with 10;8;1 compression with pistons. I have automatic compression releases in my heads/
You can get a 50mm screaming eagle cable driven throttle body that comes with larger 4.9 injectors for around $330. It’s a good deal since it comes with everything you need and may fit your build well. I’ll be using it with a 110 with fm level b heads and woods 999-6a cam, as it was recommended by the guys at fuel moto.
part number
27623-05A Comes with larger 4.9 injector. Manifold not needed. https://shop.newcastlehd.com/part/27623-05a
B. SCREAMIN’ EAGLE PRO 50MM
EFI THROTTLE BODY*
Higher flowing for larger displacement race engine applica- tions. Includes throttle body and unique intake flanges and seals. This big bore throttle body features a 50mm throttle plate (a 4mm increase over the ’06 Original Equipment throt- tle body) to provide increased airflow and more power. Higher flow rate injectors provide 25% more fuel to complement the increased airflow. Sensors, injectors (with a flow rate of 4.9 grams/second) and the IAC stepper motor are fully assem- bled on this bolt-on unit. All EFI-equipped models require ECM calibration (priced separately). For race application only.
Fozzy4325
02-26-2014 05:32 PM
Invictys
08-27-2011 01:25 AM
