Best Way to Clean Cylinders
I have a 2008 Street Bob that I am doing a build on. The bike is pretty well stripped down now and the cylinders are as accessible as they are going to get. They are painted black w/ the edges machines so that the silver aluminum shows. What is the best way to clean the cylinders? Is there a clear paint that can be sprayed on so that the stay clean longer, or will all the clear paint just burn off?
Cleaning cyliders.
Best to try some sort of biodegradable cleaner like "Top Gun" made by Gunk. Spray it on room temperature, let it soak on the surface for a minute, rinse away with cold water. Repeat.
Will likely take several applications but it doesn't hurt the aluminum (non Caustic) like a lot of the stronger caustic or citrus cleaners which will dull your machined fins. After you get them all clean, spray on that Harley engine detailer. Kind of like armor all for the black paint.
Titan56
01-14-2011 09:45 PM
