Corrosion resistant black bolts for engine
Received 5,373 Likes
I use black finger nail polish for the turn signal hinges, the front brake banjo bolt and banjo itself. Front brake splitter (under bottom triple clamp.) And other various places that are unprotected from the elements. Bear in mind that I'm close to the ocean, so "on shore drift" of salty air is a constant.
Just went out and looked. It's time t re do these pieces again, (after 3 years.)
i can get you a picture of the bottle when I get home, but it’s like gel enamel or something. I’ve got it on literally every bolt just to “black it out” but it holds up fine. Directly on the rocker box bolts, on the exhaust bracket bolts right behind the hot pipe. Holds up fine...and id it ever chips, easy touch up.
jrobinson424
02-15-2012 07:58 AM
