B2121, starter is not running
Neutral light is on, Have checked clutch in, kickstand and other possible combinations, but no go. Fuel pump runs and all lights are as normal when I turn the ignition and Run switch on, but when pushing the start switch, the headlight goes off, fuel pump on, then nothing. Starts if I jump it from the starter to the battery. Now there are one DTC left on the BCM diag. B2121 (Starter Output Open/BCM Malfunction?)
My bike is FLD 103 2014
FYI, The OP hasn’t posted since the three posts he made to that thread three years ago. A “one and done” member as we call them.
Ricochet59
11-04-2012 04:35 AM
