Question for the engine pros
I have had all winter to spend thinking about changes I want to make to the bike. I was contemplating removing the S&S 570 camshaft and replacing it with an Andrews TW37B
Question is how much, if any change in power would I find? I always thought I may have over cam'ed the engine when it was built.
Engine details are, S&S 97" cylinders and pistons, Heads from a 2008 96" engine, ports have been cleaned up but not ported. Compression ratio is 10.0:1
What do you think?
What do you think?
Why do you think it's "over cammed?" I also have 97" S&S pistons, with just over 10.5:1 compression. I do have headwork, but have an S&S 585 cam. I've actually been thinking about higher lift in the future... Maybe your cam just doesn't suit your riding style? Mine is pretty much aimed at the 2nd half of the RPM range...
Andrews 57 isn't available for the 88" or as a conversion cam as far as I can tell.
Ultimately I would like the power to come on at a little lower RPM. It comes on strong at 3000 and revs to 6500 fine but that's not where i run it very often.
As far as I have been able to find out even the heads from a 96" don't flow much more after .500" of lift.
Aside from the 57 vs 37, I am very happy with the 37 cam but never tried the 570. The machinist who did my cylinders and builds most of the custom motors in Central Iowa runs the 37 in his 2003 95" dyna. If you already have the compression up to 10.0 it would work great for you if you are unhappy with the 570. It will come on earlier than the 570. I hear the higher lift can be taxing on the pushrods anyway and don't get you much more flow.
