Shuddering on Decel
04-11-2019, 06:41 PM
Shuddering on Decel
So, new crank assy and compensator. rough idle, a little rough up to 3k, smooth at 3k, vibration over 3k, shudder when you crack off the throttle. Shim the compensator?
04-12-2019, 01:50 PM
Maybe the primary chain tension? The chain causing some harmonic vibrations when unloading.
04-15-2019, 10:13 AM
Could be. Just had the cover off to change the compensator. Looked o.k. then. Don't know how long those tensioners should last.
04-17-2019, 08:10 AM
Using the stock auto-tensioner?... ditch that pos... install a Baker.
04-17-2019, 08:24 AM
04-17-2019, 09:23 AM
RinTin
Milwaukee Eight (M8)
07-31-2017 08:22 AM
07 deluxe
05-23-2014 02:47 PM
bosscarr
07-26-2013 06:46 PM
MidnitEvil
05-10-2009 11:30 PM
creekhed1
04-19-2009 06:02 PM
