Why is rear axle installed from right side?
If I had to guess it is so that you have to lower the swing arm to allow clearance to remove the tire. Otherwise when changing the tire people would elevate the bike to get the wheel out and if they didn't support the wheel the axle mount and alignment could get malformed or damaged. This way you have to raise the bike and lower the swingarm so that the wheel is on the ground and supported when the axle is removed.
It's installed that way for proper tightening of the axle nut. Torque specs are from the nut side. If you reverse your axle then you will need to tighten from the "bolt" side of the axle and your specs won't be right. How many times do you remove your rear tire? Is pulling the shock bolt really that big of a deal?
Andrew4566 (04-12-2019)
