vibration over 70 mph- 2013 SB
Received 4,309 Likes
Vibratrion at 70 mph
Senior thanks for the reply.
Vibration starts at 70. Mostly a fine vibration which blurs distant vision. It started out of no where about 6 months ago. No additions to bike.
Now that I put a Predator motor mount on the front its vibration has increased at all speeds. I plan to remove it next week and place a oem . Don't believe everything you read, especially about Predator. They have very good marketing. After this , I am just going to live with it. Its not worth the effort. Another member suggested getting a new bike, which isn''t a bad idea( new Low rider for me), but just thinking of the things I have to do to get it right for me is too much.( Dual front brakes, Fuel moto manager, seat, bags, sissy, pipes- etc.) . Maybe next year.
This mount is super interesting... you may give it a try. It uses metal mesh in place of other dampening compounds like rubber. I guess this type of dampening is utilized in airplane motor mounts.
https://www.kineticstructures.com/ha...ne-motor-mount
Check your fallaway and tires/pressure
Dav and Senior and Elind.
Thanks for the ideas. I had the balanced checked and the air pressure is fine. I did not check the fallaway, but it seems fine and not loose. As for a new type of mount, I am going to wait till I hear from others in my area that have use it. I am a little weary of new " bandaids.
I am also going to tighten the springs on my Ohlin shocks( the model with the reserve tank) two turns to see if that helps. I may also tighten fallaway a 1/4 turn when I remove the Predators.
v
