Lite clutch kit?? 40% easier clutch??
I do some minor mods to the cover when installing the kit.. This make sure that the clutch is adjusted with the ***** at the bottom of their travel in the races. This typically requires a slight shortening of the cable spacer. I add an O ring to the spacer. Might even take some of the bend out of the cable..
Green arrow points to the spacer.
The following 2 users liked this post by Max Headflow:
crusader1xxx (07-20-2019),
F86 (04-30-2019)
I'd heard about it.. Also know a guy that tried the +1 set with the damping ring and he had issues.
The green arrow simply point to the spacer. It doesn't go there. It goes on the threaded part of the cable. I just happened to take the pic when the spacer was sitting in the cover (some time ago). You can see it in both pics plus an extra O ring.
The following 2 users liked this post by Blue Bob:
Max Headflow (04-30-2019),
SixDD (04-30-2019)
SixDD (04-30-2019)
There's no free lunch. Without mechanical assist (hydraulic pump, vacuum, etc.) the only way to reduce the effort is to increase the leverage. With fixed throw of the lever, increased leverage comes at the expense of movement of the clutch, hence the sensitivity to correct adjustment; you simply aren't moving the throw-out the same distance.
I wonder how a new aftermarket clutch perch and lever would effect the above. Do we have anyone running that combination? This also offers 30% reduction in required force; example: http://www.elitemototech.com/product...bkcl-combo.htm
