Looks like I'm going to be the huckleberry for the killer mike carburetor...
Will try to get it ordered this week? Hopefully..
He did my carb. I couldn't be happier. The only time i have to use the choke is when it's approaches freezing temps outside. Pretty quick turn around, very responsive to emails also.
Good to hear brownie.... Could you see an performance improvement?
Had you had or done any other work? Cams pipes? Little things..
Just curious..
Thank you sir for your words of wisdom..
Yeah man I've done it all. Big bore, cams, head work, 2-1. The biggest things i noticed after getting it back we're easier cold starts and significantly better throttle response.
Pulled the trigger on the carburetor... Hopefully it will give me a bit more pull... And response...
Will post more when it arrives hopefully in a week or so.
Glad to hear it. I hope you have the same result I did.
I got my carb all fixed and EZ mixture screw installed with a 6" hose attached to the screw for reach..new jets for elevation all set n ready to go. Thanks for all the help
