Exhaust Resting on Oil Dipstick
Put a custom exhaust on my 2004 wide glide. Problem is the rear cylinder exhaust pipe is sitting directly on the oil dipstick. It is sitting on top of it. Would have to remove to check or add oil which would be a pain. However, the bigger question to me is heat transfer. I know the cap is metal but I worry about possible melting plastic dip stick or I ring. I thought about wrapping that part under shield. Any thoughts on this and my paranoia. Any help is appreciated.
JayStronghawk (05-23-2019)
Campy Roadie (05-20-2019)
Received 4,284 Likes
Exhaust
Yes it is a model that actually goes on a softail and was modified to fit a dyna. I am not concerned about getting cap off to check and change oil as I can do that by just pulling it a little loose. More concerned on the heat issue before I pull it off. Just wanted to see if the heat will be an issue for rubber seal and dipstick. Any thoughts on that issue.
