A question on starting my 103 Dyna twin cam
My recent to me 2014 Dyna Switchback has the 103 twin cam engine. It has about 5k miles. I've ridden it less than 500.
It usually fires right up and settles down. But occasionally, especially if it's hot. The engine will not start right away and instead back fires. It spins normally. Just doesn't start on the first try. This is relatively rare.
Is this "normal"?
Once it starts, it runs fine.
Thanks
Is this "normal"?
Thanks
Vapor lock usually is a problem with carbs. The fuel lines on an injected bike are highly pressurized.
But it could be a hole in the gas line inside the tank. You can usually see or hear it if there is a low level of gas in the tank, but a pressure test is a better way to check it if there's nothing obvious.
When you start your bike do you wait for the fuel pump to initialize? If so, try pressing the starter switch right after you hit the run switch.
Get the battery load tested just as a basic precaution.
ZEROPILOT (05-22-2019)
I wait a few moments after turning on the switch before hitting the starter button.
It almost sounds like the timing is off when it does that.
Many times, itll fail to start twice in a row with backfires. But spins nicely.
If I toggle the switch off and back on it starts right up.
Yes, but, if the pressure leaks out the lines close to the engine can get vapor bubbles in them. It causes hot start issues that only occur of you wait long enough for the bubbles to form and disappears if you wait longer for them to cool down again.
