New wheel bearings and tire now brakes rub.
I have an 08 fxdf and i recently replaced front wheel bearings and tire. I made sure to keep the spacers in the correct location. Currently the longer spacer is on the clutch side of the bike. Put it all back together and noticed bolting on calipers that the clutch side caliper had a good 1/4" space between forks and cliper and the brake lever side of the bike was pushed too far into the fork to slide into place. Got it together and brakes drag very badly and calipers are not centered over the rotor when viewing from the rotor cutouts. So i thought maybe i installed the bearings wrong as i dont have a special installer, unless you call a hammer and socket a special installer. Slid the bearings around and its better but still not right. So i measured from face of the rotor to the center of the wheel. And it seems to be an offset wheel. Has anyone run into this before? Im thinking i pulled a rookie move and have the tire on backwards. But im no harley tech. And i do have a service manual. Thanks
stilup (05-26-2019)
There can be quite a few nuances as far as wheel/tire/bearing assemblies are concerned
Your FSM actually does state to start the 1st bearing on the LEFT Front (different years and models have better "Manual" descriptions though).
What can be the hardest part on some Dual Disc wheels is determining which side is the LEFT if you're not familiar with wheel.
Well, it was a "Rookie" Move , but don't be too hard on yourself ... it also happens to people "who get paid" to do that work
Edit: i did notice all the fatbobs of my era have the valve stem on the brake lever side of the bike. So im hoping i got that correct.
did you get it?
Is the axle shouldered? Seems like you have to get everything loosely in place then you can slide the axle into adjustment by using the hole in the axle, then clamp that side down, then tighten axle nut. Also the spacers I think are chamfered on one side so maybe check that.
chevdude
08-02-2011 11:12 PM
