Tachometer Wiring Question
I get you. I did research but there was alot of confusion. Is my fxdc 2011 single fire or dual fire? i believe its single fire. If the tach is set up to read the pulses correctly i should be ok? Many folks have used this tach w/success.
https://www.amazon.com/Bikers-Choice...a-571188310535
From the description..
"Electronic. Note: For dual fire Sportster, Big Twin."
It will also work on systems that have a RPM output from the ignition module..
You will need one of these.
From the drag specialties catalog. I'm sure bikers choice has one..
I've used these style tachs on EVOs from drag, custom chrome and autometer. Fortunately for me I had a tach output.. I've not had to use the adapter.
Your dyna is single fire.
One thing to note is that I'm not sure how well the adapters work on the newer coils. The Dynatech one is likely nothing more than a couple diodes. In that case, it may not work at lower RPMs where the dwell time is short.. On points stuff and early module stuff where the coil resistance is 3 ohms or more, dwell time is long. Newer stuff used 1/2 ohm coils which mean the saturation / dwell time is short. The Baron one might work tho..
Phil McGrath (05-31-2019)
My Softail has a riser mounted tac. I found a scrap of three wire cable with a black shieth that matched the one coming out of the clam shell. I had to enlarge the tack cup wire hole. I just pulled the electrical wires from it and easy feed the tac wires thru it. Goes down by neck and into tunnel passageway over motor. I only ran it till out of sight.
Looks like it came from the factory. Sure a fancy large industrial electrical outlet place would have it. Home Depot wire rack may have something to can do something similar to my scrap.
