Tachometer Wiring Question
#31
Max Headflow (06-07-2019)
#32
welp as it stands, I am not an electrition. I broke down and bought https://www.jpcycles.com/motorcycle-...ies/compu-fire I guess if i wanted to reverse engineer this thing I would need to buy a a few more.
1) What I got out of thos experience is theres a great group of guys on this board. Honest and knowledgable.
2) yet again i get spanked in the *** by trying to be cheap. Really thought i had a a workaround. but that drive got me through school. If u cant get it to work . find something that does.
#33
dysfunction1 (06-14-2019)
#34
Yeah, That's the big one if it works. It may be ok tho if the transistor/mosfet is over speced and has proper heat syncing (which we don't know).
#35
I should have the product. We are talking "drivers", "diodes", dual fire, single fire. Aside from sending a siginal to the, whats to qualify this product as "good" or accetable?
Seems alot of people are scratching their heads on this. More to confusion AutoMeter (usually the only gagues i use) has procycle cyclepro whatever that can be singlefire
#36
started re reading the instructions and decided to forget what I know and do what the directions said. rewired the tach wires from coil to tach adapter and pink to tach.
dual fire converted to single fire. On the 2011 FXDC there is no magic pink wire nor 3rd pin at ECU, nor a tie in at the spedo, nor special harness, that was phased out some time between 06-08 best i can tell.
Jay Guild (06-11-2019)
ghira75
06-30-2013 07:13 PM
