99 FXDWG - Hand control connector location?
I’m putting 16” ape hangers on my 99 Wide Glide. With the tank off, and staring at the backbone tunnel, I can’t find the stock hand control wiring connectors to splice in the extensions. The 99 shop manual says they are located in the backbone, but no exact location is provided. The Burly instructions say they should be near the neck, but i’ll be damned if I see ‘em. Any help is appreciated.
Thanks
Cowboy
Thanks
Cowboy
Received 4,911 Likes
CowboyKen (05-30-2019)
More info found
I did a second search for more info on this and found another thread that mentions that on 99-01 era Dynas the main harness is bunched up in a loop under the seat which takes out the slack. The suggestion is to remove the back wheel and fender for easy access, loosen that loop, and then you’ll have slack to pull those connectors out from the neck. Then pull them back in from the rear.
An an amazing piece of design....easy to work on...
thanks to everyone for all the help, and sorry for reposting something that’s been covered.
Back to it!
cheers
Back to it!
cheers
sixshooter
2014-2023 Touring Models
01-23-2015 05:34 AM
