Reduced Effort Clutch
Here's one that a bunch of people use. No personal experience, but according to Burly it fits your bike: https://www.burlybrand.com/product/2...lutch-kit/1077
fhartell14 (06-02-2019)
There are several clutch springs available. The spring for the stock 96 inch engine is pretty light to pull. The problem is that a light-pull spring often will not hold the clutch plates tight enough together to avoid slipping with hopped-up motors.
I upgraded my 96 inch to 103 and made several other enhancements. The result was that my stock clutch slipped under the more robust power. Problem solved. I ordered and installed an Alto Carbonite Clutch that includes an extra plate. I kept my stock light spring. The extra plate clutch stopped my clutch slippage and allowed me to keep my light-pull stock clutch spring.
A significant extra benefit is that the take-up action of the Carbonite clutch is fantastic. It's smooth and predictable.
Received 5,373 Likes
You could get one of these: https://www.ebay.com/itm/Easy-Pull-L...item3d852b76fc
I got one, but have been waiting to drain/change the oil to install it, though I hopefully will get it done this weekend, when I have to change out the rear drive belt, which requires pulling the primary off (which seemed a ridiculous design flaw to me).
